Zortrax M200 Extruder Head won't move in the x or y axes
At first I thought I was just having an issue with the end stops because error #034 kept coming up, I switched out the end stops and tried to make sure the contacts were as plugged in as I possibly could- but I think this may be a bigger issue because even when the 3d printer is off and unplugged I can’t move the extruder head. The table can jog up and down but nothing can move along the x or y axes. The next idea I have is to open it completely up and see if anything is clogged, but I just wanted to ask if anyone had experienced this first.
Also thought I should mention, I was able to print a blob by holding the end stop switches, but there was no movement by the extruder during the print job.
Thanks for the help in advance,
Thoughts_Filed
