WellZoom - Desktop Extruder
Hi everyone!!!
Looking on the internet I found this product. Very interesting. Various models and speeds, some even produce 1 kg in about 3 hours.
I would like to share with you . Has anyone bought?
http://www.desktopextruder.com/En/Product.asp
See the Description off the Model A:
Your Current Location:Home > Products > Desktop extruder > Desktop filament extruder(A) Product Name:Desktop filament extruder(A) Product Detailed:PARAMETERS:
1. Extrude Speed: 300mm/min~650mm/min
2. Diameter: 1.75mm and 3.00mm( 2 nozzles)
3. Adapt material: PLA ,ABS, PVA and wood-plastic etc.
4. Working temperature: below 300℃
5. Temperature control accuracy: +/- 1 ℃
6. Power: 150W
7. Power Supply:220V AC,50 or 60Hz(110VAC,50Hz to be customized)
8. Size: 502x135x252(mm)
FEATURES:
1. Simple and beautiful appearance
2. Multiple protection to ensure that equipment work with high reliability
3. Easy to operate
4. Special screw,high efficiency extrusion
5. Easy to clean the material cavity and change the nozzle.
6. Able to meet most of thermoplastic materials.
7. Able to color. It can meet your needs about the color and material of filament.
8. Air-cooling + self weight traction, making it more convenient and efficient.
Hello I recent bought mine and I changed mine I was wondering if you help me set them
Of course I can. What is your doubt?
