Weird Issue w/ Anet A8
For some reason, the extruder on my A8 is unable to produce enough force to push the filament through the hot end. When I use software to advance the filament, the motor turns but the filament doesn’t. If I do the same but put pressure on the filament prior to it entering the extruder to help it along, it extrudes just fine. Could this possibly be a clog or is it just bad design on the A8. What should I do to fix it? I don’t have the budget for a new extruder setup so I’d rather not go down that path unless I have to. (I plan to upgrade in the near future though)
I think you should disassemble the extruder and do a thorough cleaning!
Two videos that might help you!
Basics: Cleaning out a clogged nozzle!
How to fix your cr10, cr10s, mini tornado, ender, A10 and others jamming or under extruding.
Did you tighten the drive gear on the extruder motor?
Yes, it ended up being the spring being too loose coupled with a slightly offset hot end. Once I tightened the spring it seems to work fine.
