Test procedure for filaments
I want to create a test procedure for filaments.
I have some ideas :
Material related :
- Strength
- Diameter
- Color
- Transparency
- Environmental criterias : biosourced, biodegradability, …
- Post processing
- Flexibility
- Certifications (RoHS, FDA…)
- Compatibility with printers
- Spool
- Packaging : protections against humidity, …
- Origin
- What makes them different ? Original ? Interesting ?
Print related :
- Adhesion : heated bed settings, kapton…
- Speed
- Temperature
- Fan
- Retraction (distance and speed)
- Layer height
- Flow
- Wrapping
- Risk of nozzle clogs
- Odor
- Delamination
Do you see something else ?
I will publish a test soon on my blog www.si2w.be/blog
Thanks !
I forgot the risk of wear on the nozzle, flexural strength, typical tensile strength, elongation, and tensile modulus.
What’s usefull for you ?
Thanks !
Very good idea! That would be great to have more informations about filaments. I guess that we all experiment alone on our side and it would help the community a lot to share what we have found to be the right setting for the right filament on a specific machine.
Sure ! I will add this feature on Filaments.directory :wink:
Thanks for the comprehensive procedure! We’ll be sure to use it in our reviews at Isele Bros. 3D printing.
Hey,
There is a standard for testing of 3D printer filaments created: http://www.3dprintmaterials.guru/talk/516
Probably that might help you in some way.
Thanks ! Good source of inspiration
Cheers
Thanks ! Great source of inspiration.
