Is it possible to treat the Surface after printing, that i can improve the roughness to “Ra3.2” ?
Which methods are used for surface finishing?
Kind regards,
Linda
Kind regards,
Linda
Surface Finishing is an underappreciated aspect of 3D printing. Depending on the technology being used and what application is being considered, a quality, uniform surface finish can mean the difference between a successful or failed part (e.g. higher resolution = less aerodynamic drag).
If you would like to learn more about surface fishing, check out the blog below.
https://www.fisherunitech.com/blog/3d-printing-support-material-removal-surface-finishing-hardware
