Start 3D Printing with Eaglemoss V3 Help?
Hello Every one.
Have bought 3D printer Eaglemoss. But cant to start something to print.
Green libht button wokking.
But when I press in V3-3D- Create and Print.
But when press button Slice printer doing nothing all stay. No working.
How to start?
I first time with 3D pronting but something or wrong or I dont understand.
Help Please!!!
Thank You
Email-alexanipko@mail.ru
initializng printer connection, uploading data to printer. this could take a while
Writing but red line not going up.
Hi I have a couple of questions:-
Have you calibrated the printer and set the height?
Are you using PC/MAC?
I use Laptop Window 10
Yes. But its no starting. Just I seen one time blue button switched on. But now always green on printer. May be somebody know how reset all and start again??? Thanks
I know this may be a silly question but is the lid up or down when you click print?
Also does the option to print online/offline show?
Does the option for print online/off line show?
Also have you sliced the file first?
I online tried and ofline. Sliced pressed to but he doing nothing. May You can send me some file for slicing and print Please. Thank You
Can you go into manual control for the printer
click connect
then test that the nozzel is heating up185 deg, also the print bed 55 deg
Chris
Its in setting? Yes I will to try. And what posicion need stay heat table? Just when I move into my room table sliding another place. Or how can reset all? Thank YOU
No table stay and all
One time been table moving by himself but after start button from front stay blue light not green
All I am doing at the moment is checking that the nozzle and print bed are printing
Also find an stl file for you to print :slight_smile:
f-11d_blaster_rifle_starwars.stl (630 KB)
Ill try tommorow. If not send you message.
But in which position need to be table heating before I switch on?
Thank You
the table before you switch on should be at the bottom of the printer, it will rise up to the print nozzle when it starts to print.
