Hi all, I have an OBJ file that I generated from a drone flight. It is a view of a building in a field. I would like to be able to cut/trim away the outer excess areas I don’t want. In other words, looking down from the top I have a building in the middle of the area. I want to cut or trim away all of the excess “land” around the building so I can print the building and just what is close by. I don’t need to do fancy editing of the file but basically crop it as you would do to a photo.
Hi @wirlybird I’m probably missing something here (it’s early) but can you not just load it into your preferred editing software and trim it using boolean subtraction?
