Sir.
I want to gift my friend a 3d model of him
so what cost would it incur?
how many days it to make a model ?
Sir.
You would need a large 3d scanner to properly print him, otherwise it would be a lot of guess work
What I would do if I were you is take pictures of him from all sides and use Versa Connector (TNDCI DEV) 0.0.1 - Sign On to generate a 3D model from the pictures.
Once you have the 3D model, choose a 3D Hub near you, and it will give you a cost based on the size and shape of the model. Each Hub has its own pricing and average delivery time. Most have a turnaround of only a few days.
I agree
You would also have to scale it to a good size otherwise cost would increase or decrease.
Hello, i could do one for 50€ all included for 10cm 24hprint, bigger size is possible, are you in Paris ?
If you are in the LA area i can perform a full scan for $50. It would not take more than an hour. The print would be base on the size. I can go up to 11" on PLA. Something that big would probably be around $60-80. Total is Less than $200. From the day you come to take the scan it will be 4 or 5 days depending on the print size. https://www.3dhubs.com/los-angeles/hubs/inventions
Hi
we are located in Bangalore we have both facilities let me know what size due u required then we will able to tell you the costing.
Regards
Deepak
Dont you have any branch in mumbai?
Making a model of a face by hand is taking a veey long time, but you will need to find a 3D scanner. There are apps who can do the job
Do you have a 3D scan model ?
For quotation, we will need a 3D file.
We can print in plain white or in multi-color
If you have a 3d file of your friend, the cost would depend on size and resolution of the 3d model.
Also, depending on size and resolution it could range from a few hours up to a day or two to print.
Thank you,
Paul
Hey
First of all before we can discuss this matter: what region are you from?
Taking a scan and printing a model isn’t an issue. We can do that.
Regards
Dirk
If you are in the NYC area i can perform a full scan for $50. It would not take more than an hour. The print would be base on the size. I can go up to 8" on PLA. Something that big would probably be around $60-80. Total is Less than $200. From the day you come to take the scan it will be 4 or 5 days depending on the print size. https://www.3dhubs.com/new-york/hubs/dhaval
@INVENTion Sorry for copying lol
Hello Abhishek… We are based in Mumbai and can do the scanning and printing for you… Let me know… 9820079332
