Prusa i3 X heating issues
I’m hoping to find a solution. I was running a 6 hour print and left the printer to do its thing. When i returned I found a massive glob of ABS had encased the hotend. I heated it back up and removed all the ABS and cleaned the block and wires yhe best I could. Since that incident during a print the hotend never heats up. The bed works fine and also i can run the prepare function and it will get up to temp without issue. The minute I try to print from sd it goes cold. I have tried several files just incase it was a gcode issue. Nothing has worked. If someone has a trick or suggestion or if Im missing something please let me know.
My printer is a Prusa i3 X
