Hi all,
I have mistake with 3011 / 3013 (they change each other).
I have done everything I need in the instructions.
- Set 5 new heads.
- Lubricated all rails, cleaned etc.
- Changed on new POGO PCB and Pogo Flex Cable.
- Took on to check another E-box and Festoon cable.
Problem still exists. After flashing firmware the date is lost, how to return the current date and return the printer to print?
03/06/19 13:19:20 0 19 Printer: Rev: 5.243 May 9 2013 16:22:09
03/06/19 13:19:36 0 19 Printer: PCBINFO: ZPrinter 650 Add-On card serial number does not match flash drive record. Updating record.
03/06/19 13:19:36 0 19 Printer: PCBINFO: previous value: 6601xxxx-574DF5C9-04, new value: 65111xxx-54B65573-04
03/06/19 13:19:36 0 19 Printer: PCI v323, AddOn v234, Pogo v320
03/06/19 13:21:31 0 19 Printer: Empty overflow canceled, recovered less than 0.05 inches
03/06/19 13:28:59 0 19 Printer: Smart purge started
03/06/19 13:28:59 0 19 Printer: purge heads 0.000e+000 pixels
03/06/19 13:29:02 0 19 Printer: Smart purge took 0.03 minutes
03/06/19 13:29:17 0 19 Printer: start job
03/06/19 13:29:17 0 19 Printer: pixel count:0:50348965888 1:6299090944 2:8028037120 3:8598970368 4:5633474560
03/06/19 13:29:50 0 19 Printer: CheckHome fast LM629:2 SEQ:-1
03/06/19 13:29:50 0 19 Printer: StartJob waste bucket is 26% (990 grams) full
03/06/19 13:29:52 0 19 Printer: SEQUENCER: Timeout, SeqStatus:0x14, SeqIRQ:0xc007, PogoCtrlReg:0x1e5
03/06/19 13:29:54 0 19 Printer: SEQUENCER: Timeout, SeqStatus:0x14, SeqIRQ:0xc007, PogoCtrlReg:0x1e5
03/06/19 13:29:54 3013 20 SEQUENCER: timed out finishing swath, flags = 14
Date broke
05/21/09 00:00:22 0 19 Printer: Rev: 5.243 May 9 2013 16:22:09
05/21/09 00:00:40 0 19 Printer: PCI v323, AddOn v234, Pogo v320
05/21/09 00:04:30 0 14 Monitor: (00:04:30) TLV2556SPI: comm successful after 1 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) POGOFIFOSPI: comm successful after 1 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) POGOFIFOSPI: comm successful after 2 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) ADC conversions thrown out [test registers: 4095 4095 4095]
05/21/09 00:04:30 0 14 Monitor: (00:04:30) POGOSTATUSSPI: comm successful after 1 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) HP11BROADCASTSPI: comm successful after 1 retries
05/21/09 00:04:30 0 14 Monitor: (00:04:30) HP11READBACKSPI: comm successful after 1 retries
05/21/09 00:04:30 0 19 Printer: (00:04:30) SEQCONTROLSPI: comm successful after 3 retries
05/21/09 00:04:30 0 19 Printer: SEQUENCER: fifo underrun, SeqFlags:0x424, SeqIRQ:0xc306, PogoCtrlReg:0x155
05/21/09 00:04:32 0 19 Printer: SEQUENCER: Timeout, SeqStatus:0x14, SeqIRQ:0xc007, PogoCtrlReg:0x3e5
05/21/09 00:04:35 3013 20 SEQUENCER: timed out finishing swath, flags = 14
