Problems with a certain print. Support coming loose.
I have attempt to print this 5 times with automatically generated supports. About 2 hours to 2 hours and 30 minutes into the print a support will come loose. I have tried adjusting different settings, but at a loss now. Others have been able to print this without issue according to comments.
Any help would be greatly appreciated.
http://www.thingiverse.com/thing:714533
If the support itself is coming off of the bed I’d say that you should try to increase your adhesion (glue stick, maybe more heat). If the support is separating from the main body of the print I would decrease your x/y and z support distances to maybe get a bit better hold on the part.
Hope this helps!
-Martin
Thanks for the reply. I finally got it to print using the slicing software Flashprint.
