Problem in stratasys 3d printer
Kindly help me
when i do the tip to tip calibration after some time printer gives “Error no 3 no convergence” and stops and when tip sensor is removed the error is changed to tip sensor problem now i have installed the tip sensor and its functional test is done it is ok at load its normally close contact is broken and it is ok
kindly sugest me possible solution
Hi Hussain,
Is this occurring on a Titan or Vantage printer? It could be due to the Z zero needing to be adjusted and we can help with guiding you through this procedure. Please let us know.
Thanks,
Aaron
