Print Bed not adjusting
I recently received a JGAURORA 3D printer and am trying to calibrate the print bed. The bed is not moving when I click auto home or disable steppers what do I do
Hi Sir, may I know which model you purchsed, where did you buy it ? pls send email to JGAURORA support with problem pictures : yuki@zgew3d.com
meanwhile,check the cables connections if they are tight
I am not familiar with your exact printer but one thing I will often forget to check is the Z end stop.
does it fix now ?
you will want to check to be sure its not lose and isnt slipping. then re-level your bed.
pls send me email for easy communication. order ID, machine photo . thanks ! email : yuki@zgew3d.com
