Pinshape selected value 3d scanner EinScan-S!
Pinshape - “The Einscan-S features two scan modes, an automatic scan and a free scan mode. The first is the easiest, simply place your object on the Einscan’s rotating turntable surface, and the machine will scan your object in just 3 minutes, down to an accuracy of .1mm. For larger models, the free scan mode works by rotating the scanner on a tripod around the object. The Einscan-S generates a single STL file that can be sent straight to your 3D printer."
https://blog.pinshape.com/the-11-best-value-3d-scanners-on-the-market/
Shining3D Scan sharing Act is opening now!
See scan cases already submitted by other EinScan-S users via www.einscan.com
This is definitely something for you, @victorp :wink:
@Alice_SHINING3D Einscan sounds really great! Hope you don’t mind me adding the video to your thread, so people can have a better understanding of its capabilities. Thanks for sharing! Any models we can have a look at, on Sketchfab or anywhere else? Cheers
Yes really cool !
Some comparison between physical model / scan result / print result would be soo nice !
Yes! Definitely! Thank you for your help. @gabriela3d
We have uploaded hundreds of models on Sketchfab. https://sketchfab.com/einscan​
Model scan
https://sketchfab.com/models/fe5815d56a5946efba0064c404ecc449
Color texture scan:
https://sketchfab.com/models/ba6e32292bc64a5494abcb50516067bb
Thank you for your tips. Actually, we did some comparison between white light scanner (EinScan-S)and laser scanners, and we also compare the scan result and print result, you can see the pictures below. @victorp :wink:
The eagle scan and print is just amazing !
