PETG bonding
I am using PETG filament, a model that I recently printed took over 10 hours to print, when separating the print from the support material, part of the print snapped off. I have tried using super glue to bond the two parts back together but it isn’t a strong bond.
What is the best way to bond two PETG parts?
I can’t believe, here in 2019 already, how hard it is to find any info or easy answers to bonding PETG.
Has anyone had success with bonding / gluing PETG parts to PETG and other materials? Any experience with the below Loctite products?
The ‘low-energy’ polyethylene part of PETG seems to be the big challenge for most adhesives.
Interested in PETG to PETG for general use, and PETG to carbon steel for grips on a hatchet.
Had a helpful conversation with a Loctite technical rep, and am considering these three products:
Loctite HY 4070 - a two part ‘hybrid’ cyanoacrylate/acrylic gel (mix of both the below chemistries)
https://www.henkel-adhesives.com/us/en/product/structural-adhesives/loctite_hy_4070.html
https://tdsna.henkel.com/NA/UT/HNAUTTDS.nsf/web/4C6E8EE50B4C2765852580A70055C71D/$File/HY%204070-EN.pdf
Loctite AA 3035 - two part acrylic methacrylate adhesive gel system designed for bonding low energy plastics
(same root as above)/structural-adhesives/loctite_aa_3035.html
Loctite 480 - toughened (rubber added) ethyl cyanoacrylate with high shock resistance.
(same root as above)/product/instant-adhesives/loctite_480.html
Also interesting is the Loctite 4090…, a variant of the 4070.
These are all expected to work with low energy plastics, and a couple of them specifically reference as good for polyethylene.
Appreciate any suggestions for other products, too.
Thx - scottmi
Here are some discussions that may be of use.
https://forum.simplify3d.com/viewtopic.php?t=9281
And actually a simple Google search came up with thousands of good hits.
https://www.google.com/search?source=hp&ei=511lXL2OEYHatAXm8pfgAw&q=glue+petg+parts+together&btnK=Google+Search&oq=glue+petg+&gs_l=psy-ab.3.1.0l2j0i22i30l7.1527.4038..7117...0.0..0.74.505.12......0....1..gws-wiz.....0..0i131.11RXZjGJq1c
