Pcb plus plastic printing?
Any body knows where to be able to print the body plus the pcb inside,at one place as i dont see its available on 3d hub?(example an electronic toy?)
Usually plastic toys are printed in two parts (shells) which can screw a PCB onto inside using standoffs and screw hardware. You wouldn’t want to print a toy and have a PCB “entombed” inside it without having access to it to fix/replace etc. Do you have the STL files for the plastic body? If you sent a local hub the PCB they may be able to assist in fitting it into a plastic shell design when the print it?
Steve
Thank you Steve! That’s what i meant some one that prints both… For a reasonable price as in 3d hub…
3d Hubs is only for printing 3D plastics, not electronics or printing/etching PCB layouts. Your best bet would be to find a local “makerspace” or “hackspace”. They would usually have both a 3D Printer, and/or a laser engraver or CNC machine which may be able to create the PCB… you would need to find them locally to you, but you may get lucky?!
Steve
Thanks for your help
