Hi. I am a novice with autocad. I have a simple item that I made by joining 2 pieces. It is now a 1-piece polygon. I will attach a picture. There is a small gap between the pieces and I do not know how to remove the gap. Please help!! Thank you, Lori
hi, iv only used inventor for modelling but i assume that software is similar, so when you are constraining 2 pieces together usually there is an option to offset the part so you should be able to move it closer. im not realy sure how you got a gap from connecting them. One reason this could be the case is you have constraint the pieces to the axis so it can move on z but not x and y. in that case try constraining the 2 faces together. also is it 2 separate models or did you make them just separated on the same save file? if thats the case then im not sure how to connect them.
Do you need help and design assistance?
I work as 3D modeler preparing objects and figures for 3d printing.
Have done many different type of projects, got experience on object assembly.
Should you wish to see any example of my work I would be pleased to show them to any of the following internet addresses:
impresiondesign.wordpresscom
If you are interested, email me back, I have very razonale prices.
Kind regards,
