Hello! I’m new to 3D hubs, and I’ve been working with a NextEngine Scanner for about a month now. I’ve got four .scn files with fusing issues that I would like to find someone to work on, resolve fusing and output .stl files. The files are two complex objects and two hollow vessels. Pls let me know if you can help - paid. thanks!
Hello Erasmus,
im using the Sructure Sensor 3D scanner and clean my object wih the free program Memento from Autodesk. Its original made for photogramitry scan’s but it works good with laserscans as well https://memento.autodesk.com
Robs_3D
Hi Liz,
I’m also a NextEngine user and might be able to help. If you launch an enquiry through my Hub I’d be happy to take a look.
Thanks,
Joe
