Makerbot Rep Gen5 and Simplify3d 3.1 - need good tested profile exported .fff - Help
Hi New to this board and new to 3D printing although not to CNC
Although the new Makerbot Print is better than the descktop I still like the features of Simplify3D.
I have used the default setup for the Rep5Gen in 3.1 and tweeked it about alot (maybe too much).
Not getting the results I expect. So
Is anyone out there using the Makerbot Rep 5th gen with Simplify3d 3.1 and have better luck, can you export your profile to an *.fff file and post here.
Thanks, If I have more sucsess I will post mine, but stuck at the moment
Thanks … JCS
Hi Jan, post your FFF profile here and I can have a look at it for you
Hi
Thank you for looking at this, I have a Gen5 with Smart+ head.
The attached files has a DXF extension (because they do not allow posted of files with FFF extension, just change the DXF to FFF and it should open in notepad.
I have had files fail with this FFF but not all of them which is strange.
Hope you can help and I can get a reliable FFF to work with the printer. Using the new Makerbot Print which is better than Desktop but still not as good as Simplify3d 3.1.
Regards JCS
maker-rep5-smart_3.dxf (8.08 KB)
Hi
Are you having any luck with this. Please respond yes or no so I know if you are getting this and its worth pursuing.
JCS
Hi
If you are not going to reply at all why bother asking to post the file i have and saying you will help?, OR is it that you needed an FFF file for a Makerbot and did not want to ask!!!
JCS
sorry didnt see you posted the profile
will have a look at it over the weekend, havent played around with the profiles we are using, but the main thing is turn on rafts for now
Hi
I was loosing hope on a reply so very please to have one. Can you post the FFF (exported) that you use so I can also look to see if I can spot any differances. I may have just messed up the original. Change the .FFF to .DXF then it will alow you to post here.
Regards Jan Skraba
In desperate need of an FFF for Simplify3D to run my Makerbot 5th Gen. Been battling and tuning for weeks now.
Errin in Louisville
egnadinger@yahoo.com
