Hello, I have a roll of pet filament and it has been jammed in my printer, which is a flash forge creator pro. I have loaded the filament but it won’t print out and it is not unloading or extruding. (in my experience now, I am beginning to think this filament is just expensive but very bad quality). I have tried heating the extruding to high temp and attempting to pull it out, but it is not working, any suggestions???
https://www.simplify3d.com/support/print-quality-troubleshooting/#clogged-extruder
Here are some suggestions
Hello gautam2000 - What temperature are you heating up to? Did this jam happen mid print? I would like to help you. Let me know if we can have a trouble shooting call tomorrow.
Adam Grieser
Director of Sales
Sounds like the nozzle is blocked with hardened lump of filament. Are you able to remove nozzle from the machine?
You should be able to use a hot air gun to heat it up to it’s working temperature and be able to poke in and around both side of the nozzle. You could also use a method of inserting ABS, set the temp to about 180 and performing a cold pull which hopefully will grab the hardened lump thus removing it.
Hello, thank you so much for your help. I have been having some issues with your filament recently because every time I load it into the extruder it is jamming. My extruder is at 250 degrees celsius, and yes this jam happened a few seconds after the print started. I heated the extruder to 280 degrees celsius in an attempt to pull it out, but it is not working. I haven’t had this issue with any other filaments. Is their anyway to resolve this issue without taking apart the extruder?
