Hi guys
I’ve recently developed a Laser cut Calibrator out of Acrylic. Would anyone be interested in this for their machine? It makes calibrating a breeze when you actually have to do it. Lmk or send PM via message system!
Hi guys
Hi Cotterpin,
Sounds interesting. Do you have any pictures you can share?
Cheers,
Marc
When you say calibration, do you mean a grid of a specific size with the number of rows and columns set the same as the default image?
I made a vector (DXF in the case of the attachment, although I usually use the SVG one) grid and then depending on the resolution I want, I scale it and then either print it onto transparency film or laser cut it onto acrylic.
Is this the sort of thing you have? Or do you do it a different way?
192mm Guide.dxf (588 KB)
Yes this is the method I use, but I have all 3 scales locked into 1 pdf/cut so there arent 3 separate images
