When I first received my printer just before December the 25th (QIDITECH Dual Extruder), I was able to set-up and print two models which came out good.
Since then I’ve had zero success, to keep things simple I’m trying to print just a very simple model to ensure the settings are correct and that the printer will work.
I create a circle 30mm in diameter, then extrude to 20mm and then create another circle inside this which I extrude down to 18mm, so the model is a cylinder with a 2mm base and 2mm wall.
I’m printing with ABS, with bed temperature of 100 degrees and extruder temperature of 230 degrees.
The software I’m using is Fusion 360 with Makerbot. The printer starts off by heating the bed and then the extruders, it then starts with the print which I have to terminate almost instantly as the filament gathers around the extruder and then is just dragged around during the print which doesn’t stick to the bed.
The initial filament that is printed on the bed before the model starts printing does start by the model doesn’t.
I’ve checked the bed and extruder gap using the levelling paper that came with it. I’ve looked around online for some information on exactly how to level the bed and I think I’ve done it correctly, there is a slight bit of friction between the levelling paper and the extruders. I start of with front left, then front right and finally centre back.
I also have PLA and PETG but i’m not succeeding with any of them…I’m using paper tape on the print bed as when I first started I couldn’t get the print off the bed, and this helped as its easy to remove.
