How do i switch from ABS to PLA?
My Printer (Da Vinci 2.0A) wont load PLA Filament. I bought original PLA from Xyz-Printing.
I switched the chip in the catridge but he didnt load.
Do I have to install something?
Please help o.o
Gray or blue sides? If gray you’ll need the updated extruder to run pla. If your machine is under a year old you can get it free from xyz.
My sides are blue
is this the new Version?
Yes you should be able to run pla. Do you have 2 cartridges of pla installed?
nope, have only one roll of pla.
do I Need a second one?
Is it possible to just remove the other one out of the plotter?
You can use just one but as you said the other slot needs to be empty. The machine expects 2 of the same or only 1 in the primary location (right hand slot).
Ok, tried this yesterday, it didtn worked either.
Just switch the roll inside the roll inside the cartridge and the chip?
does the plotter changes the temperatures itself?
Yes.
oke :smiley:
thanks so far
will trie this again, and will come back if it make more issues
okey
now he accepts the catridge, but he dont print anything… no filament comes out of the nozle :frowning:
Yes, you should have to instill a driver.
