I recently found a Makerbot Replicator dual extruder( wooden frame) in a free pile - someone was moving and didn’t want it anymore. It is in perfect working condition and even came with two full rolls of filament.
After some research, I decided to download the last version of Makerbot Desktop. However, when I try to print a file I get the error “unexpected error while starting print.”
Next I decided to try updating the printer software. It is currently on version 5.1. But when I try to update there is the error “unknown error from conveyor.” I tried varying the timing between hitting update and pressing the restart button, but it still didn’t work.
Finally I tried to export and print from an SD card. But when I chose the option “print from SD card” on the printer it takes me to a screen where the only choice is “exit menu.”
After that I gave up trying to fix the problem myself and reached out to customer support. They gave me a download link for an older version (3.7) of Makerbot Desktop. I followed their instructions to get rid of the newer version and installed the older one. However, I got the exact same errors as before. I asked customer support again, but the answer they gave didn’t help.
After more research I decided to download the even older Makerware and try it. Makerbot deleted all the download links for Makerware, but I was able to find a download someone had saved on a 3d-printing forum. However, when I connect the Replicator via USB the messages “Replicator Dual Connected” and “Replicator Dual Disconnected” appear simultaneously. When I try to print the file, the “print directly option” is grayed out. I also tried exporting the file to the SD card using the file format recommended for software version 7 and below, but the same thing happened as before.
I also dowloaded ReplicatorG in the hopes that it would work (I found old forum threads where people were recommending it for the Replicator), but it just gives the error “unable to connect to printer.”
Starting to suspect that something was wrong with the USB cable, I tried two other cables and multiple USB ports on the computer, but had no luck. I think that the USB port on the Makerbot is broken, and that’s what is causing the problems, but I want to make sure before I try to fix it. Maybe updating the software on the printer will also fix the SD card problems.
