filament extruding problem
The filament will ‘load’ – and continue pushing filament through in that mode – so I assume the gears are ok ( the same gears drive the filament through whether it’s loading or printing, correct?), but when I try to print it seems to extrude a little and then stops. The printer continues as if it’s printing, just no plastic is extruding… no filament is being pulled in. But when I cancel the print and then go to ‘filament load’ to see if it’s clogged, filament comes through the extruder just fine. I’m pretty confident it’s warming to where it should… I’ve just replaced the approx 1.25" piece of plastic tubing and have cleaned out the extruder point (guitar wire). Any ideas? thx, jg
