I would like to 3D print an item, but I need to scan a real object and get a 3D model to start with, and then make some changes to the model and print it. Any recommendation for 3D scan services? Thanks!
We are based on Spain, and we offer 3D scan services. If you could send the item or give us a reference where we can buy the same item we could get te 3D model.
Hello, I can scan the modell, too.
If you have the item we can find a solution.
Do you have a smartphone in your office?
And how detailed is the object?
Greetz SWS
Good Afternoon, I am a recently established printing hub for education and schools and would love to help out other business in the field of design and 3D Printing. I also have 3D scanning abilities. I am located in NJ and would be able to help out immediately. Should you have any questions, please do not hesitate to ask.
Jason
I use https://remake.autodesk.com/about from Autodesk you can use it free to try. After that you can import your model in tinkercad or something else
The big plus of it is that you can use your own camera
You can always send it to us, check me out on Instagram @TheAirborneArtist what’s the object? Laser scanning is best for real replication and reverse engineering.
John,
I would be happy to look at the Part that you need Scanned. We are a firm that specializes in 3D Scanning, Reverse Engineering, and 3D Printing. So I can help you with Scanning into CAD Format, Reverse Engineering & Changes, and then also with the print. Thanks!
