I’m currently trying to set up a Deltawasp 2040 for ceramic use but am struggling to get clay adhesion to the base plate on all of my models. I thought it might be the clay mix that is the issue, but I am able to get the same mix printing correctly with some models but not with others. Any help on how to create adhesion would be great.
1) about the fail prints: are you sure that the models have a flat surface and were laying properly on the bed?
2) one way to have a good adesion is to make by hand a clay disk and put it in the print area
3) when I print in LDM mode, I use a circular wood plate
4) as usual, the levelling of the plate is important: I feel good keeping very low space between the nozzle and the plate at the first
5) at last also the velocity affects the adesion of the first layer: keep it very low
