Davinci Extruder Problem
Greetings all,
Im relatively new to the 3D printing world and really only do it for the fun of it but recently my Davinci 1.0 A has been giving me problems with the heating element in my extruder. i was running a print over night when the spool jammed up and stalled the machine. i didn’t get to it for about 8 hours when i cancel the print and restarted my machine, i ran into a problem with the extruder temp
At first it would only heat up to about 50 or 60 degrees then after changing my settings to default and restarting my machine it wouldn’t go above 20 degrees and stagnate around there till it gave me the 0011 error. I scowered the web for answers and i came up with 2 things. 1 its the connectors or 2 a fuse blew on the mother board.
I stripped and soldered the wires together that the connector was holding and from what i can tell the mother board has no blown fuses. I checked the voltage the cord was out putting and i’m only getting roughly .3vs.
would anyone else know what else might be wrong / what it is i could do to fix this issue?
I had similar issues, it could be the (thermistor?) temperature reader, your hot end is most likely getting hot enough but the printer thinks it’s only 20 degrees or so, it might also be the heating element that’s broke and barely heating. Luckily both parts are cheap and I believe most decent online places will sell those parts, never go to XYZ as ordering from them can be a real pain.
i ended up switching to an E3D hot end a while ago, it was well worth it. The stock DaVinci hot end is ass.
Unfortunately I’ve had the same issue twice, I’ve had to have the motherboard replaced twice by XYZ printing. I just replaced the motherboard about a week ago that had the same issues it stems from the J4 however I have a wiring harness issue also with the extruder check to see if there’s any shorts in the line. That may be the issue
All the best keep me posted
ive checked the J4 fuse and it doesn’t seem to be burnt out and I’ve already gone ahead and bypassing the janky connector and soldered the wires together
Is there any way to test if it’s the thermistor? im starting to realize the Davinci was not the way to go. I’m trying to weigh my options on either paying for parts to fix it or just cut my losses and go for a lower end machine. I don’t use it nearly as much as I use to.
Use a blow dryer and check to see if heat goes up, on the extruder I feel your pain I just did this about a few weeks ago unfortunately I had to get a new motherboard there were no other options in my case
all the best
ali
I had this exact same problem and I figured out how to fix it. First take the extruder off of the x axis bracket. Then open up the extruder until you can see the entire circuit board by unscrewing everything. With my printer there was burnt plastic around the gold piece that heats up which should be cleared. Then I also found a piece of plastic leaking out of a plastic tube in the extruder. Once i cleared those pieces of plastic it worked. Hoped this helped!
it raises in heat when i heat it manually. so that would probably be a mother board issue then?
I believe you can test thermistors with a multimeter but they are a few pounds or dollars each and fiddly wires I wouldn’t want to strip. So I’d buy a new one along with a heating element and wait to try them. There is a small board on the extruder that might be the cause as well but I fear you have to do go XYZ for that part. I do feel it’s just a crappy thermistor though, anything else would either not work at all or just work, the thermistor however can be giving weird values.
the DaVinci isn’t bad, it was cheap when I got mine 5 years ago I think but I have since then installed Repetier and installed a new E3D extruder and hot end. If you feel it’s a bust then I’d look for a printer that’s already Repetier and open source, they are much cheaper now.
It could be a short in the extruder wiring, use a multimeter I also have had that issue. also ended up putting new connectors because the cheap crap to fix the problem.
The new motherboard Did cost me $75
from Xyz printing
The Da Vinci is not a bad printer
It’s very easy to modify
All the best
