Hi I recently got a CTC dual printer from ebay. Ive went through many posts about this printer but I just want to make sure what I know is correct and up to date.
As of now,
- the only software that is compatible with CTC Dual is MakerWare 2.4 and RepG.
- If I were to use other slicers i.e Cura Id need to use GPX https://github.com/whpthomas/GPX to convert the gcode to a .x3g (which I can only print from an SD card. Is there a way to print it via USB connection to PC?)
- Firmware I have now is 7.2 (from the repG output log) or ‘The Creator 1.0’ from LCD.
- Not quite sure what advantages I have by upgrading to 7.7, but if I do Ill just have to follow the instructions from the Thinigiverse link http://www.thingiverse.com/thing:32084
Also current prints of the 20mm calibrations boxes are okay overall but the top layers are not bridging properly. I used makerware 2.4 with settings:
PLA filament
2 shells
0.2mm layer height
210C extruder temp
60C bed temp ( i find it sticks easier with 60 rather than no heat)
extrude speed 90, travel speed 120
infill 15%.
I successfully did one with extrude speed 30 travel 60 but I’d like to get prints out faster in the future. In Cura I see that I am able to control the top and bottom layer speeds but I cant seem to print them out using the .x3g code I converted with GPX. ( I used the UI version)
Sorry if my questions are confusing but Id appreciate some help. Thanks!
