Nice! Are you going to finish it with an epoxy or something similar to make sure it sticks? Have you thought about overmolding it with a 3D printed mold and some silicon?
no not yet ! for now i’m just doing some research about 3D technologies, but more specifically with SLS and nylon 12 makes up more than 90% of SLS current market. Then I was wondering if it could be as usefull to FDM machines.
How hard is it to remove support material from your nylon parts? We’re having a tough time with removal using Taulman 910 when printing parts with overhangs that need a lot of support. We don’t have Simplify3D software and are curious if it works better than Cura/KISSlicer for making supports that are easy to remove.
It is hard to remove support material, We used clear or white pla as support material, not nylon.
We redesigned the steering wheel in order to reduce support material.
The only software that can handle nylon support material is “Eiger” which only works on the markforged 3d printer. Support material comes out almost flawlessly.
