Acceptable Files
I’ve made some stuff on Rhino 5 software, is this able to be printed at certain hubs or is this only compatible with Tinkercad?
You just have to select the model you want to print inside Rhino 5 and file/export it has a *.stl file. Then Rhino will ask you about the mesh control parameters. I use 0.01 as value. It works for me most of the times.
If you can export it as a stl file, you should be able to get it printed on any of the hubs.
We’re not too far from you, if you need help.
Adam
Thanks very much!
If you can export it as an .stl file we could most likely print it for you depending on dimensions and we are in Rushden
