A little problem with the bed
When i use Cura for splicing, at the end of printing, the bed doesn’t go down to the origin but remains on the top. With Splic3r i don’t have this problem.
What i can do?? Thanks
Hi @Tantingtree857,
Try to reset the gcode, of use the following gcode.
;Start GCode Cura 14.07
;Basic settings:
;Layer height: {layer_height}
;Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used:
;{filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
M190 S75 ;{print_bed_temperature}
M109 S220 ;{print_temperature}
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M907 E1000 ;set extruder current to normal state
;only needed for Trinamic-Stepper
;not needed for UM2-Original
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed}
;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing…
;END GCode Cura 14.07
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit
;before lifting the nozzle, to release
;some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed}
;move Z up a bit and retract filament
;even more
G28 X0 Y0 ;move X/Y to min endstops,
;so the head is out of the way
M84 ;steppers off
;{profile_string}
This setup already exists…nothing changes. I checked it and it’s correct. What to do?
Have you tried to uninstall and re-install cura ?
Yes done, nothing changes.
And another bizzarre problem: after 15% of printing, the printer stopped himself, i don’t know why, and on the display i read “attend personnel”…i click the button and printing starts again till the end…mah…very strange…i think i’ll come back to Slic3r!!!
Copy your end.gcode from slic3r, and paste to Cura.
Before doing this you might want to delete or comment out end.gcode from Cura
cheers
phil
