Raise 3D N2 Plus
I’ve have decided to move forward with the Raise 3d n2 plus. Wish me luck. Lol
Great, please share your experiences! Feel free to give me a call if you’d like to answer a few more questions before your order: 859-903-5857
I appreciate it. I’m completely new to 3d printing so I’m sure I will be asking alot of dumb questions
To be expected at anything new. I’ll be happy to answer little questions here or there, otherwise I’ll forward you to other online support groups. If you buy the printer through ArtLab (at no cost difference to you) I can offer a lot.more help.
What I think is a quick and easy question. The way I understand it the Raise 3D N2 Plus comes with the bed pre-leveled. How do you confirm that it’s level and make adjustments if needed? Note: I don’t have the printer yet.
The bed does certainly come pre-leveled. It’s very rigid. You can watch this video to get more info on what you should do once your Raise3D has arrived: - YouTube
In short, you calibrate the distance between the nozzle and the bed with a knob on the left hand side of the machine. If you are replacing the bed sheet or buildtak, always be sure to check this before printing. Move the extruder by hand to the front, left corner and then Home the Z axis using the touch screen. You can see more in that video above.
that doesn’t sound to bad
How does the BondtecExtruder help as have had no success with flexible materials like Ninja flex
Also had nothgin but problems in general with dual extrustion and attemps to use supprt materials Hipps, poly support and PV along with Nylon and Poly PC
raise_3d_materals_problems.pdf (652 KB)
polymaker_pc_plus_support_attempt_4.pdf (3.15 MB)
polymaker_pc_plus_support_attempt_1.pdf (4.34 MB)
15_oct_pla_attempts_to_make_a_pla_moai_statue_.pdf (338 KB)
How does Simply 3d help with Nylon as had no sucesswith it using a Raise 3d n2 dual V2 .Certainly no luck with lexible materials
polymaker_pc_plus_support_attempt_1_0.pdf (4.34 MB)
