Hello Gaa, How soon will you be in the market? Pls keep us posted. Best wishes.
Gaia,i mean, pardon for typo.
Good evening the theater is already built and we’re finishing the complete automation of the system .
In the shorter I can provide a data sheet of the technology we developed scrivetici well to our direct email for more information gaiasolutionsnc@gmail.com
Hello KauPang,
I would like you to evaluate a couple of files. See if quality is print worthy (no need to print yet) and give me a quotation for 3 sizes : 9, 12 & 15 cm in full glorious colours.
I will send you first .PLY and then .OBJ. One of the files has good lightning not so much the other.
Is it OK to send you the files? Your quotation would be exworks, no postage required yet.
Tks & rgds
LAD
PSD. And where are you located?
Although Sense 3D and the structure sensor might have pretty much the same precision, the structure sensor is definitely better if you compare both scans. This is because Occipital, the guys behind the strcuture sensor, have released an SDK therefore there are a lot of good apps that are already available for scanning objects, people or even spaces (like room or interiors).
Some of these apps (like itseez 3d ) do a post-processing of the scan that ends up in very good results. Obviously still not comparable to professional scanners but sill good considering the price of the device.
Here you can find some of the scans I have done with the Structure (it was during an event with very bad lighting and I used an older version of the app, now you can also do full body scan and not just busts…):
https://sketchfab.com/FrancescoPusterla/folders/817b53f4ad7d4fad8ef7322d204821df
Gaia solution advice to after extensive testing using the ProJect 660 Pro for the construction of minimum , Shapies … we also tested a printing process to make the best joints for info please visit …
Hi guys, just a heads up that I moderated your contact details out. Moving forward, please use your hub profile as a way of contact. Cheers!
Hello LAD;
Sorry for late reply - missed your msg. I am located in Norway. Pls. send files, and you will have a quotation. rgds. Bjorn
Sorry for that,
We’ll keep that in mind! Thanks!
Hey imalize,
Where did you get all the motorized parts in your scanning setup? I’ve been looking for a turntable and scanner rail system. Any info you can provide would be greatly appreciated!
thanks,
mark
Hi mark !!
There is a tutorial for a basic model to build :
I’ve had those projects bookmarked for a while now. I was wondering how you motorized your scanner rig. Got any references for how you did that? Maybe a few close-up photos would help!
Regards,
Mark
