I have been printing a few things that have shown signs of over extrusion with a Wanhao i3 v2.1 and PLA. Particularly something that had a 2x2mm hole in, that probably came out only 1.2x1.2mm and the rest of the base looked a bit squishy. A benchy had a bit of a squished out base and some roughness on one side.
I went through my usual extruder calibration technique, heated the extruder to 190, extruded about 15mm to prime the nozzle, measured 120mm from the top of the extruder then issued:
G91
G20 E0
G1 F100 E100
Once the flow stopped, measured the distance and it was spot on 20mm, brilliant, sounds perfect. However my current e steps is 107, which compared to other bits online sounds high.
Out of interest, I heated to 195 and tried again. Doing it twice, without changing the e steps, I was left with 30mm - clearly under extruding. The calculation says I should go to 118 for my e steps. Whenever I push it that high, I start getting all sorts of random results.
Does this all sound a bit high, or should I be using a different feed rate?
